Can't wait to read the replay on this conversation with the electrician...Those screws look like they will be corroded off in a week or two.
The screws and clamps need to be rated for direct burial.
Copper Screw for Use In Direct Burial Applications
Nice build, thanks for the deets!That's why I'm thinking a layered defense. Yard, then a 4 ft(?) Mulch barrier, then a 5 ft pavers with rocks barrier, then the pool. Grass clippings will be trapped by the mulch, the mulch will occasionally enter the first foot of the patio area but get caught in the rocks between the stepping stones and the pool stays pretty clear. I can stand at the pool and blow anything encroaching, back to where it belongs when the need arises.
At least. Scribbled in crayon on the napkin in my head
I specifically made the pool a few inches higher so it will slope down on all sides away from it. Doing that at the old place kept the mulch around the patio where it belonged 'downhill'. Mowing got some grass in the much but it didn't get to the pool.
We watched our existing brick patio get overrun by ants since we moved in and it's all out of whack now. If we go with bricks or pavers around the pool it's only a matter of time until they are all sinking and all that sand gets blown into the pool. It was a never ending battle at the old place and I had several handfuls of sand a week to vac out.
I'm not sure how we will like a cement patio cracking over the years, need to get some quotes to talk to the cement pros. Last time they were all against it here but would install one if I wanted them too. We love stamped concrete but took their advice last time.
That leaves me with the stepping stone idea which just so happens to be the most affordable.
The more I think about it, the more my head hurts.![]()
Those screws are stainless steel.Here is one similar. I'll check them later to be sure
Morris Products Direct Burial Copper Ground Pipe Clamps – for Connecting Grounding Electrodes to Water Pipes, Tubing, Ground Rods – 2-10 Wire Range, 1/2-1” Water Pipe Range, 1/4-20 Screw Thread: Electronic Components: Amazon.com: Industrial & Scienti
Morris Products Direct Burial Copper Ground Pipe Clamps – for Connecting Grounding Electrodes to Water Pipes, Tubing, Ground Rods – 2-10 Wire Range, 1/2-1” Water Pipe Range, 1/4-20 Screw Thread: Electronic Components: Amazon.com: Industrial & Scientificwww.amazon.com
I guess that other customers just don't check these things.James for the win # 3.715 X10E65. Magnet sticks. Texts sent to GC and electrician.
But HEY !!! I have a bond wire with the appropriate copper clamp attached to the grid, so 2 out of 3 is some progress.
I'll go all of the above. Nobody anywhere seems to care anymore.Either they don’t care or they are completely incompetent.
You sure earned your weight in steaks with that work!!I could remove the patio myself in a day and I don't make $1000 a day
LOVE it! That is Karma being on your side!an area rug
I'm not renting a trencher twice so I was the machine today.
Your poor body!!! Here! Have a cold onegas auger and punched as many holes fit across, then only needed to remove loose dirt knee deep, which was still no fun, but better.
You NEED one of these:I'm not renting a trencher twice so I was the machine today
