They got about 2/3 of the way at 3k. I could have aimed the nozzles a bit more up and hit it for sure.At 3,450 RPM, the jets should be able to reach the deep end wall
You ain't kidding. So much sitting around waiting and then BOOM, pool, in a day.This thread went fast all of the sudden.
We ran three hoses. Used up ALL the water pressure. But the pool filled up pretty fast!Running a separate hose from another spigot seemed to make a big difference for me. Just don’t try to do laundry, take a shower or run the dishwasher because you will have absolutely no water pressure..
My logic is that if you are going to send a pool warming gift, the gift should be able to warm the pool.
Donated a tshirt as a sack of CYA. I let it soak in a storage tub overnight and moved it to the return this morning now that it's a better water height.
I have 10lbs going for now which will give me around 30. I will SLAM first and then go to 70 for the SWG.
*** You new folks pay good attention here. Stop making excuses to avoid a SLAM and start making excuses to have an easy one that might even be completed the first night.
I tried to and the 10lb sack that I already tied up like a roast only fit in the bucket one particular way. It was so tight in the bucket that it didn't get much flow from the fill pipe.Hey, you should have put some of the CYA in the diffuser (the orange home depot bucket contraption) !
#Preach. 1 gallon is 4ppm for me. I went shopping *one time* for enough gallons to make it until the salt dissolves and that was *too many times* wasting an hour and a half finding bleach with empty shelves, or old stock if the store did have some.I am jealous that you are adding salt right away. The beauty of a liner pool.
I'm brushing and brushing to no avail and I stepped to the side to get a different angle of attack and the sediment moved with me. I was brushing the reflection of a cloud.![]()
Rub salt in the wounds why don't ya !!!!Been a while since you did this pool maintenance stuff?
Sock method in the skimmer maybe?So the pic doesn't do it justice of course but there was a white sediment down stream of the CYA sack.
It was NOT by my doing.![]()
When I started last night the skimmers were still high and dry so I wasn't concerned with size. This batch won't fit now that the skimmers are full.Sock method in the skimmer maybe?
