The pool has that dye that turns red when people do that.I could warm the pool but it may mess up the chemistry.
Also, Newdude has thermal cameras with A.I watching for heat signatures.
No, my friend, it is not.Is that second skimmer supposed to be closed at this time?
well at least you had the tool needed to fix it but still!!!
Well the gaskets are under the trim with nothing I can see exposed from the top. But I watched them install them so here is to hoping.PLEASE tell me you can see they put the gaskets on correctly!
Because you left your vehicle running in the street, only expecting to be here 10 minutes.Seriously I mean how do you miss that!
The worst part is when you realize that you should have cut the liner on the Inside of the faceplate.Absolutely nerve wracking holding a razor over the pool.
Signature stays. If it works, we'll still all be here and you can ask me what kinda pump I have if the need ever arises.Time to update your signature
You realize you just jinxed yourself - again.Signature stays. If it works, we'll still all be here and you can ask me what kinda pump I have if the need ever arises.![]()
