Desperate need of help. I have a couple questions and need all tips u have.
Backstory: Few weeks ago we got a new liner. As the pool was filling we saw the water coming out was brown. City water. Not well. Installer said to level the chemistry and run filter 24/7 a few days and we would be clear
Did that. It didn’t clear. Shocked it. Not clear. Metal out. Nothing. Tests for chemistry are all in range. Even the iron test showed zero. Used socks on returns and poly fill in skinner for weeks. They were turning brown but nothing was changing overall in the pool
So we flic’s it. Now it’s all on the bottom.
1. If the particles were too small for the filter take remover after running 24/7 for weeks, would they be larger and heavier now so I can vacuum through filter?
2. Better to vacuum to waste? And how do I do that? I tried last night and couldn’t tell that it was vacuuming only that a TON of water went to waste before I got very far.
3. Is this the beast tool to use to vacuum it?
4. Should I try to vacuum through the filter and add socks on the returns again?
5. Do I turn off the skimmer not connected to the vacuum hose and the main drain?
6. Do I backwash first, last, and do I open the valve going out to waste when I backwash and rinse?
After crying in frustration last night, I’m back today begging for help and willing to try again. I am having such a hard time learning to do this while fixing the issue. Not even sure if I am posting int the right thread. I may resort to posting in multiple.
