Deep end discussion:
So I thought I would start this thread for the purposes of logging useful information and, perhaps, teaching others. I am currently doing a differential drain of my swimming pool whereby I am removing water from my deep end well using a submersible pump and some PVC plumbing while I am adding...
www.troublefreepool.com
Simple answer:
Put the sump pump in the deep end if you have a saltwater pool and/or your fill water (likely 60 degrees in champaign) and your pool water is 60 degrees.
I would put your sump in the deep end, and fill on the top of your shallow end.
To make it simple, take a 5 gallon bucket. Time how long it takes to fill from your hose. Mine was about 60 seconds or 5 GPM.
Put the sump in and do the same. I had to put the hose from the sump over a ladder to increase the head (increase backpressure) to match the sump output to the hose input.
Let 'er rip and monitor the pool level. If it is rising, turn off the input for a bit. If it is lowering, turn off the sump for a bit.
