- Jun 24, 2021
- 15,940
- Vinyl
- CircuPool RJ-60 Plus
You should do this in one exchange without running the pump. The water is stratifying based on temperature and TDS. You are putting new water on top in shallow and removing water from the deep end. If you stop (and particularly if you run the pump), the water has a chance to mix, reducing the effectiveness of removing old water and adding new.Gave it a rest over night. Exchanging again now that I can keep an eye on it periodically. I'm curious what you mean by "no going back" once the pump has been turned on. Thanks.
Example: CYA=100. Let's say you did 10% exchange and stop. You mix. Your CYA is now 90. Then you exchange another 10%, it will only reduce it by 9, so you would be CYA 81.
If you had done the 20% in one shot, you would be at 80.
It's just recommended that you do it in one exchange to be efficient. Don't fret over it, you are doing great.
