No, unfortunately, I didn't.When you took the voltage readings around your pool with the wire attached to the bonding point on the pump motor did you happen to switch to continuity as well and test the bonding grid?
Yup, it was a significant 2-year project that just finished in early Spring this year.*my second guess is my original guess. That the massive road widening behind OPs house on the big + sign intersection had all the poles replaced somewhat recently. Missing or faulty bonds/ grounds is causing otherwise unlikely bleed offs in the general neighborhood
That would indicate to me that the railing in the shallow end is probably bonded ok. It is the water that is energized. Even though the pump is bonded, the resistance in the water is sufficient to maintain the voltage difference between the pool and and pump bonding or even the light bonding although the pool shell should be bonded as well. What is the pool surface?I didn't post on this yet, mainly because of time. After doing everything that I did over the weekend, I ran a bonding wire from the pump and did some testing. I don't have the measurements in front of me, I specifically remember the anchors in the shallow end only had like 50mV AC. The decking over near it was around 1.8VAC. Water was around 2.4VAC, deep end ladder area all registered around 2.6VAC, area at the deep end light was around 2.6VAC as well.
I’m sorry that I can’t always explain it in a way that makes sense to all y’all way smarter than me with EE backgrounds / knowledge. Sometimes my gut just knows before I can prove it.But I agree with the others that the recent electrical work is certainly very significant.
Yes, they added a retention pond next to my house on the east side. The pool is higher in elevation than the pond; by how much, idk.Are there any bodies of water nearby?
If yes, what is the elevation relative to the pool?
The pool is vinyl with an ABS/Fiberglass wall.What is the pool surface?
My neighbors' small shed near the easement never had electricity to it and has since been torn down. Thanks for thinking of itAlso worth noting in my map looking ats……. Still have crummy service and can’t upload but there was a shed behind the pool abouts where the sewer easement would continue up if it kept going.
maybe the shed has its own CO / electric meter fed past the pool.
We are a thorough bunch !! You loves us.down. Thanks for thinking of it
I love your thinking.....but that's an 8-foot deep hole I would need to dig Is there a tool that you know of that can dig a 1.5" hole and travel 8' deep?It might be worthwhile to dig a few 1.5" holes straight down as deep as the pool to see if you hit water
