None that are advisable before 811 does it’s thing. After that you can get your power auger on anywhere it’s safe.Is there a tool that you know of that can dig a 1.5" hole and travel 8' deep
+1. Go gentle just because. No jumping on the spade to hammer it home over 15 inches deepI think it is safe to go <2' into the soil without 811. All utilities should be more than that and if it isn't, it isn't likely a utility anyway
This tells me that the railing is bonded, because it has the closest voltage to the pump. The rest seems to have lost the bond to the railing.anchors in the shallow end only had like 50mV AC. The decking over near it was around 1.8VAC. Water was around 2.4VAC, deep end ladder area all registered around 2.6VAC, area at the deep end light was around 2.6VAC as well.
You need to be careful with this some of the utilities I have seen less the a few inches below the ground and I have seen cable tv that was laid on the surface of the ground and sodded over.I think it is safe to go <2' into the soil without 811. All utilities should be more than that and if it isn't, it isn't likely a utility anyway.
Any newer CATV or phone lines to the house are usually spaded in just under the grass. You don’t want to cut them because there may be costs to have the company fix them, But you won’t die if you whack one.You need to be careful with this some of the utilities I have seen less the a few inches below the ground and I have seen cable tv that was laid on the surface of the ground and sodded over
And irrigation lines can be pretty shallow, too.* gas and propane have surprisingly shallow requirements as well ‘about 18 deep’ in most jurisdictions.
I would only do it if absolutely necessary.I love your thinking.....but that's an 8-foot deep hole I would need to digIs there a tool that you know of that can dig a 1.5" hole and travel 8' deep?
You can actually get water table information from the ( I believe) county. It gets update periodically. I checked ours at 350-600' depending on where you are.It might be worthwhile to dig a few 1.5" holes straight down as deep as the pool to see if you hit water, but don't risk drilling into any lines or pipes.
Yes, they added a retention pond next to my house on the east side.
I don't know that it is always accurate to the specific local area.You can actually get water table information from the ( I believe) county. It gets update periodically. I checked ours at 350-600' depending on where you are.
Yes and yes. If someone gets shocked, bonding has failed. Since we know it is not due to the house, then it must be outside the house.Or is the belief that the grid has failed on the deep end and voltage leaks through the grid? Is that why you want to measure to see if there is voltage gradients in the soil surrounding the pool?
This type of thing scares the tar out of me. Fine that I can see that it’s only 3 V or 13 V but further down the line it could be Newdude blown to smithereens voltage.something of this type of leakage through both concrete and water must be a decently sized circuit, unlikely something simple like a cable company moca power distribution system. If you try this yourself with some form of poking in the ground wear rubber boots and rubber gloves for your own safety.
Sounds like the bonding has come loose. You can check potential with a multimeter. There are some good videos out there for it by Mike Holt.The issue: When entering or exiting the pool through the shallow end, and you grab the railing you are feeling like you are being shocked. This is not happening anywhere else in the pool. The deep-end ladder isn't demonstrating this issue.
Info: The pool was built in 2003 and is bonded with a #8 copper wire from the pool motor, over to the four corners of the pool, hand railing anchors in the shallow end, deep end ladder anchors, pool light, and the concrete rebar; it all passed inspection. This issue has never happened until this summer, June 2021.
Testing and isolating: Voltage from the railing to the concrete is about 1.5V and railing to the water is around 1.9V. When we disconnect the ground wire to the house, the voltage drops to .0023V at the railing in the shallow end, and the shock goes away. This is the closest point to the pool motor from where the bonding begins.
We have solar panels on the house. We had them come out to verify that there isn't a voltage leak or grounding issue on their equipment. With all of their equipment unplugged, power off, main breaker to the house turned off, we still had the voltage in the shallow end. Over by the pool motor, we were seeing around 3V on the ground. Absolutely NOTHING was turned on at this moment. All of the solar equipment checked out. The next course of action, check with the power company to see if there's a load issue. They came out, performed a load test, and everything checked out. The house grounding rod is secure and reads 0V. We've taken out breakers, disconnected all of the wires for the pool motor, timer, outdoor outlets, checked the GFCI's. Nothing, absolutely freaking nothing is leading us to the source.
We've never had this problem, but it's only isolated at the railing in the shallow end. I'm planning on removing the railing, cleaning up the bottom section for better contact, then taking a wire brush and running it inside the anchors to see if that helps.
All of the bonding is encased in concrete. However, is there a possibility that the anchor lost its bond? Any insight would be helpful. Thank you!
We have tons of clay in this area, and the area under the pool was dry when they built it.I don't know that it is always accurate to the specific local area.
It's always better to actually dig a hole to be sure unless you know that the water table is really deep.
Is there a well point under the pool or a dry well?
Did they hit water when digging the pool?
Do we know why the retention pond was added?
Does the pond serve some purpose?
