It’s me, it’s literally me Lmaoooo
I KNOW !!!!! You’ll come to know and love us all. But we already know you because we lived some exact version of your story.It’s me, it’s literally me Lmaoooo
Never mind on the CC question. I read ABC of pool chemistry. So now my question is, since it’s a 0.4, not a 0.5 do I SLAM?Okay here are our test results using the new kit.
CYA:70
PH: 8.0
TA: 120
CH: 200
FC: 4.4 ppm
CC: 0.4
Yes I know the CYA is high. Earlier this week we drained a quarter of the pool and it was a literal mess. Plus we have been getting rain every day here in south Florida so our yard is a flood mess as it is. I definitely can’t do anymore draining for now. It rains though so that should help it lower? Prior to the partial drain this week, the pool store recorded CYA at 96 so I think we made some progress.
From my understanding the CC should be 0 or as close to 0 as possible? Is that correct and why so? What does the 0 mean exactly.
What should we do next? OCLT or go right into SLAM. Also, do environmental factors count into the OCLT? (like if it rains etc).
Pool is not green anymore. Still brushing (hopefully dead) algae off the bottom but very minimal amounts.
Ok. We can deal. Your pool is small so increasing your liquid chlorine demand won’t hurt nearly as much.Yes I know the CYA is high
CCs are the result from the FC doing it’s thing. Chlorine eats the baddies. The baddies cry out one last gasp of breath (gas) and that’s when you ‘smell like a pool’. It’s why public pools smell so chlorine-y.From my understanding the CC should be 0 or as close to 0 as possible? Is that correct and why so? What does the 0 mean exactly.
Get to SLAM FC per the FC/CYA Levels. You want a FC of 28 and you want it to stay at 28. Anytime it dips below looses efficiency. You really want to test/add every 2 hours at first. (Do the best you can, we all have lives too).What should we do next? OCLT or go right into SLAM
Brush and vac everyday. More if possible.Still brushing (hopefully dead) algae off the bottom but very minimal amounts
shouldn't they drop their pH first? at 8 that is pretty high and at SLAM chlorine levels testing won't work.Ok. We can deal. Your pool is small so increasing your liquid chlorine demand won’t hurt nearly as much.
You want .5, preferably 0 to prove the chlorine doesn’t have to kill anything.
Test, add per poolmath, wait 20 mins and test to verify you hit your target.
the first day it can chew though chlorine. Day 2 usually holds for 4+hours and by day 3 it can be 8 hours or more. The back half of SLaM is more about filtering. You’ll keep the FC up anyway, but won’t need to add but twice a day.
You got this.
Yes. Great catch. Always drop PH to 7.2 and SLAM.shouldn't they drop their pH first? at 8 that is pretty high and at SLAM chlorine levels testing won't work
Thank you!!!! And according to that chart with a CYA at 70, the chlorine should always be betweenOk. We can deal. Your pool is small so increasing your liquid chlorine demand won’t hurt nearly as much.
You got this.
Thank you! According to the chart with a level 70 CYA, outside of slam, I should maintain a 8-10 FC level at all times but never at 5? Is it safe to swim in a level 8-10???Ok. We can deal. Your pool is small so increasing your liquid chlorine demand won’t hurt nearly as much.
You got this.
Exactly. But never ever approach a 5. In Miami you will use more daily FC than most. We average 2-4 ppm across TFP land.According to the chart with a level 70 CYA, outside of slam, I should maintain a 8-10 FC level at all times but never at 5?
Thank you both! This might be a silly question but you said I need to get to FC of 28. So do I add the entire amount of bleach recommended to get to that point right away or in intervals ? And then the whole point is try to maintain it at a 28 as long as possible until all 3 criteria is met?Yes. Great catch. Always drop PH to 7.2 and SLAM.
Yup. Pencil sized stream (to minimize splashes) in front of a return. Brush the floor good. It’s heavier than water and some could puddle up and bleach your liner.So do I add the entire amount of bleach recommended
Exactly. M is for maintain. The more you do, the shorter the process. You get busy and step away for a day, you might be at square 1. Or mostly square 1. We get it. Life happens. Don’t fault the process though.And then the whole point is try to maintain it at a 28 as long as possible until all 3 criteria is met?
Yes, was just wondering if the CC increasing from 0.4 to 0.5 was normal within a couple hours but I guess it doesn’t really matter since 0.5 is okay. Just was curious haha!While in the middle of a SLAM the only measurement you care about is FC and how close it is to your target SLAM level. Remember there are three criteria to complete a SLAM:
1. CC is 0.5 or lower
2. You pass an OCLT
3. Your water is crystal clear
That’s why you have a small army of us folks helping two. So we can *all* see something different and make you feel better about it.Also I feel like a lot of these tests and criteria’s are open to interpretation
*googley eye. I did warn you it would laugh at you the whole time. Funny little jokester. All proud of himself and stuff.could easily see the black dot
Lmao!!!! You’re right.That’s why you have a small army of us folks helping two. So we can *all* see something different and make you feel better about it.
*googley eye. I did warn you it would laugh at you the whole time. Funny little jokester. All proud of himself and stuff.![]()
