SC Pool Build
YippeeSkippy
12,433
Evans, Georgia
I know this is being picky.... and not sure if it actually *is* a problem but I caution against letting bromine water get into your pool via kids water toys or bathing suits or whatever if they were to go back and forth between pool and hot tub like mine did..... my concern is over time having bromine in your chlorine pool. When enough bromine is in your pool it then becomes a bromine pool and *not* a chlorine pool. But how much is too much?
I'll invite our resident chem experts to chime in on this fret of mine- @JoyfulNoise @JamesW
Have you considered using a small salt water chlorine generator in the hot tub? Saltron makes a nice small one that works well. Or just liquid chlorine?
Maddie the worrywort :flower:
Gibby13
72
Elgin, SC
@YippeeSkippy I thought about it and probably should have researched more if I could have got a different Intellicenter that would do my type of hot tub also.
If I went the route of liquid chlorine, wouldn't I have to add that every day?
I am still fighting on not moving the hot tub near the pool and leaving it in the garage with the projector so that we can watch movies while relaxing.
Gibby13
72
Elgin, SC
Anyone have recommendations for a 3D landscape design company? I underestimated how much there would be to do afterwards.
This wall for one is going to be a lot longer and higher than we thought...
  • Wow
Reactions: kimkats
Gibby13
72
Elgin, SC
Intellicenter came in. Also they redid some of the plumbing so I could hook up the solar heaters my dad gave me.
I kinda of which the valves were orientated in a way to quickly see the flow direction.
kimkats
43,377
Tallahassee, FL
Turn the pump on high and get the brush ready to brush until it is gone. Leave the pump running over night before you turn on the SWG so it gets mixed in good.
YippeeSkippy
12,433
Evans, Georgia
Everyone needs a pool pole, and the nice thing is is that the brush, net, hook etc are all interchangeable to the pole ends. SO you're buying one pole that serves a multitude of functions.
Maddie :flower:
Gibby13
72
Elgin, SC
I know some builders give them out around here with the package, I don't remember if one was included with what I chose or not, but will check when they come over to get the check.
YippeeSkippy
12,433
Evans, Georgia
Sure they may.... usually any of those items given out are the cheapest on the market with just a net on it. See if they'll give it to you now? Otherwise if you're adding salt now you need to just buy one and get the brush end.
They may give you a simple starter test kit too. Don't hold your breath that it will be anything near what we recommend.
Gibby13
72
Elgin, SC
So they are giving me some supplies next week and are going to clean the pool.
The electrician hasn't shown up yet, so should I dump in some bleach? Already have tons of mosquitoes flying around.
The retaining wall is about 90' long, had another company come up and is going to give a quote on doing it with stone or 6'x6' instead, just have to talk wife into it.
