SC Pool Build
Gibby13
72
Elgin, SC
Electrician came today and is wiring it all up and putting chlorine in. Monday pool builder is coming and will clean the driveway, clean the pool, and put salt in. Luckily I hadn't picked up my order of salt from Lowe's yet. I am going to just get 5 bags to keep on hand and switch the hot tub over.
Reactions: kimkats
kimkats
43,377
Tallahassee, FL
There might be some before the water starts to flow. Once it starts to flow they can be worked out. Now if there is any wrinkles or dips AFTER it is filled with water that changes things.
Gibby13
72
Elgin, SC
They came to vacuum and add salt, I counted 18 bags that they added. Dude didn't know how to make the SCG turn on with the Intellicenter.... 15 minutes later and I had the SCG on and the VSP hooked up to the Intellicenter. It is reading 4300ppm. I'll run tests tonight with the test kit.
Gibby13
72
Elgin, SC
Since I don't know if they are going to have to drain it all for the dip or wrinkles yet, I decided not to add anything, but did take a round of tests. PoolMath Logs
I put the SCG on super chlorinate earlier today and threw in the M600 to do the water line, the pollen was starting to build up.
Current pump schedule is:
24 hours 700 rpm
2 hours 1800 rpm
Gibby13
72
Elgin, SC
Pool deck drain... Pool builder didn't say anything about it and neither did the concrete contractor.... The wall builder brought it up last week. The concrete contractor said he could do it however we wanted. Either sloping the deck or putting in a drain. So I ordered 100 feet of the below, thinking it would go up against the wall.... 1585780156624.png
Wall contractor was here today and started digging the footer and said the drain should go in the middle of the deck and to have the concrete company slope it from the pool to the middle and from the wall to the middle.
Is there a rule of thumb on deck drains? Like where they go, how wide or deep they have to be?
