Saltwater pool horrible red eyes
MCF50
243
Houston
FC at 5ppm. Cya at 70. Me and my son get horrible red eyes swimming. I thought a saltwater pool was supposed to stop this. Read high chlorine (above 3ppm) can cause red eyes. But this forum says put it at 5ppm with cya at 70. So what should I change to get rid of the red eyes.
kellyfair
4,248
Tampa, FL
Intex Krystal Clear
Check your ph.
MCF50
243
Houston
All levels are within this forum recommendations. FC 4.6. Cya 70. CC zero. Ph 7.6-7.8. TA 90. CH 400
Jimrahbe
21,229
Bedford, TX
MFC,
I run an FC of 7 ppm or more with a CYA of 70 or so.. I can swim with my eyes open under water with no issues..
We need a full set of test data..
MCF50
243
Houston
We can swim under water no issues at all. It’s when we get out after a couple hours in the pool our eyes are very red. Results posted above.
PoolGate
5,577
Damascus, MD
Jandy Aquapure 1400
FC 4.6? That result didn't come from a Taylor test kit!
mknauss
37,111
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Rubbing your eyes while swimming can cause red, irritated eyes. Do you best to not rub your eyes.
kellyfair
4,248
Tampa, FL
Intex Krystal Clear
How are you testing your water?
Newdude
6,921
NY
Hey MCF !! For what it’s worth I ran hot with a target FC of 10 and a CYA of 70 with my salt. The PH was always on the high side of in range.
swimmer after swimmer after swimmer remarked how amazed they were to have no stinging like every other pool they’d been in. So I can attest that up to double your FC, it won’t matter and something else must be going on.
Kevinr14
120
Chandler, AZ
Are you putting sunscreen on your faces? Particularly the forehead? I find it always runs down into my eyes and make them sting for a while.
Reactions: kellyfair
kellyfair
4,248
Tampa, FL
Intex Krystal Clear
Yep, this happen to me too... I’ve started wearing an old baseball cap in pool so I don’t need sunscreen above eyes.
JeaniB
175
Midwest
Our tears are approximately 7000 ppm of salt. It isn’t the salt causing this.
MCF50
243
Houston
No sunscreen. Nothing. I just got in again for another hour. Blood shot. Have to use drops. No burning or anything at all while swimming. Just after. Maybe I’m just sensitive. I do get dry eyes from lasik surgery.
kimkats
48,159
Tallahassee, FL
@Dirk found out what was bothering his eyes when he got out. He was rubbing his eyes to get the water out/off. He started just patting his eyes with the towel and it worked best to keep from irritating his eyes.
NCMike
139
Raleigh, NC
I have the same problem. My eyes are very sensitive to my water and I had Lasik 5 years ago. My wife and kids can swim all day and no issues. I have just always assumed that it was the Lasik that made them sensitive.
Reactions: MCF50
