Here is last springs estimate for the lowest level product. I blacked out the contractors name
The difference is between marble based plaster and quartz based plaster. Significant difference in price. Is it worth getting the quartz based? Does it last longer?The name of the product is wet edge. Will try and get the information today
Thank you. He said he would not chip out areas that were solid and would tap the concrete to be sure there were no hollow sounds. Is it fair to ask him to chip out everything? The pool seems quite sound for the most part but have some sections where the surface plaster has fallen off—but these may be old repairs. It’s hard to have to trust someone unknown with such a high cost service. I appreciate your response and thoughts!!That's ballpark for NJ area. Prices are higher right now all over the country. What I will say is if you want a long lasting quality job spend the extra money amd do a full chip out of old plaster. That's the only way to guarantee a long lasting finish.
Is the 11k for just a plaster touch up what it should cost for the entire chip out and replace? Not sure what I am getting for my money!That's ballpark for NJ area. Prices are higher right now all over the country. What I will say is if you want a long lasting quality job spend the extra money amd do a full chip out of old plaster. That's the only way to guarantee a long lasting finish.
The pool water is slightly acidic without much calcium but some. Hard for me to get untreated water. But water that has gone through our treatment system is about pH 7.2 and Ca of 60 or so.Do you know what the full chemistry is of your well water? No metals? Minerals? pH, TA?
It is better for the plaster curing if known pure water is trucked in and the pool filled quickly. The plasterer may not warranty any work if you do a slow fill with well water.
All sort of problems can happen with the plaster finish if your well pump dies during the fill or you have metals or minerals in the water.
$1,500 to have 40,000 gallons trucked in is a very good price.
Do you think it is necessary to chip out all the concrete? They are proposing to fix some cracks and deterioration in some localized places. No one told us it was necessary to chip out everything but just those places that are obviously needed. The pool is really in decent shape considering it’s ageThe pool water is slightly acidic without much calcium but some. Hard for me to get untreated water. But water that has gone through our treatment system is about pH 7.2 and Ca of 60 or so.
