Hello all,
I’m hoping to get some advice from the experts here.
*I think the original pump/motor was overkill for this size pool, it was a Hayward Matrix pump and Hayward/Century 2HP, 2 speed motor 3450/1700RPM. The plan to replace noisy bearings changed when I found the front shaft corroded to about 1/2 its original diameter.
Would someone be kind enough to advise and recommend an efficient pump/motor?
- Horse Power?
- GPM?
- Single/Dual Speed?
- Any other misc. advice?
Pool Details:
Pool is 8000 gal. Oval 12x24, above ground
It has 150 sq. ft. cartridge filter
Changes since original equipment was installed 10 years ago…
I added a gas heater last year (2" inlet/outlet) and all the flexible hose was removed and plumbed with ridged PVC all 1 1/2".
120VAC 20AMP power at pump site
Pool is in western Pennsylvania
10 years here - 10 years BBB!
Thanks in advance and very appreciated!
- Horse Power?
- GPM?
Pool Details:
