Pump sizing recommendation
So that is an up rated 1 HP and has the impeller SPX2607C. You could go up a size with that VS motor to a SPX2610C. The larger impeller would be more efficient and quieter at the same flow rate.
If you go this route, don't forget a go-kit.
