What I would probably do is use a regular Intelliflo VS without SVRS.
I would plug the main drain from in the skimmer most of the time and only occasionally open it to flush out the line so that the water doesn't get biofilm.
Or, install a reducer in the main drain line to limit the amount of water going through the line. Maybe reduce the opening to about 3/4" so that you get a slow but steady flow.
I would make sure that the drain covers meet current code.
I would immediately set a maximum speed limit in the pump control of about 2,400 rpm.
I would get an Intelliconnect to control everything.
Note: Follow all applicable codes for your jurisdiction. If any of the above conflicts with local code, defer to the local codes.
