- Mar 23, 2019
- 86
- Plaster
- Jandy Aquapure 1400
I'm a new pool owner that has the IntelliConnect System from Pentair installed. I was not able to find much on this site regarding the IntelliConnect product, so I wanted to share my experience so far.
IntelliConnect Install Guide [ Link ]
IntelliConnect App User Guide [ Link ]
IntelliConnect Wireless Pairing Guide [ Link ]
I have what I am told is a pretty basic pool. 12K Gallon Gunite Pool with a bunch of Pentair gear (2 x Intellibrite LED Colored Lights, IntelliFlo VS Pump, Clean & Clear 200 RP Cartridge Filter, IntelliChlor SWG and the IntelliConnect automation).
The IntelliConnect is the smaller, light grey box, closest to the filter.
Setup was easy. I downloaded the app from the app store, connected to the device via Wifi (it acts as a hotspot for initial setup) and gave it the credentials for my home wifi. I did not have great wifi outside of my house so I did run a new access point to the back patio to have good wifi signal for the entire pool area.
All of the photos below are from the phone app, but the website looks and functions the same.
Landing Screen
This is the landing screen when you first launch the Link2O app. Apparently it supports multiple systems... so I have to click on my device to access any controls or details. I wish since I only have one device, it simply went to my pool.
Home Screen for Pool
This next page is the home screen for my pool. There are links to the controls (I do not have a heater so that option is disabled). At the bottom of the page you can see an overall status of the system.
IntelliFlo Page
From the home screen, if I click on IntelliFlo I see the below page. This page shows the current speed of the pump and energy usage. I can start/stop the pump, switch between the programs (1-4) and edit any of the programs. My program 1 has my run schedule (12 hours a day), so that's mostly all I use.
IntelliChlor Screen
The next option from the home screen is the IntelliChlor. This shows me the current setting for the SWG and allows me to change the setting in 5% increments. The bottom of the page shows the salt level (it's way too high as the builder added too much salt) and the water temperature. There is also a boost option, which will temporarily increase the chlorine generation and pump speed for a period of time that you can define. It defaults to 72 hours.
Relay Page
Finally, the last 2 options from the home screen control the relays (there are 2). Relay 1 is providing power to the IntelliFlo VSP and Relay 2 is providing power for my 2 IntelliBrite 5G LED lights (both lights are wired to the single relay).
Relay 1:
Initially I had Relay 1 in manual mode and on. The issue with manual mode in this situation is that, in the event of a power outage, the relay does not automatically turn back on when the power is restored. This has become an issue for me with the frequent Florida summer thunderstorms. I called Pentair about this and they stated that the IntelliFlo VSP should not be powered from the IntelliConnect Relay, rather it should have its own dedicated power line. The RS-432 interface will control the IntelliFlo and ensure that the IntelliChlor does not turn on, unless the pump is on. The Pentair rep also confirmed that with the RS-432 connection to both the IntelliFlo and IntelliChlor, in the event of a flow switch failure on the IntelliChlor, the IntelliConnect will prevent the IntelliChlor from turning on when the IntelliFlo is not running.
Relay 2:
I have both of my lights connected to Relay 2. The IntelliConnect allows you to setup one schedule for the lights, or just operate in manual mode. The best feature is that you can switch between the light modes (the IntelliBrite's have over 16 modes, which the kids love). You can of courser manually turn them on/off, even if a schedule is in place and active.
Overall I have been very happy with the system. This is my first pool and I had assumed any type of automation would have been out of my budget, but was pretty excited to see that this was standard from my builder. I like the ability to see energy usage and the ability to easily adjust the schedules with my phone and see the water temp even if I'm at work.
From an app/website perspective, the functionality is good, however every once in a while I have to kill the app and relaunch to interact with the controller. For example last night, I was trying to change the pool light colors and the app said it was working, but nothing happened. Once I killed the app and relaunched it was fine.
I hope this helps anyone who is considering this product. I'm happy to answer questions if there are any. Below are a couple photos of the pool for reference...
Landing Screen
IntelliFlo Page
IntelliChlor Screen
Relay Page
Relay 1:
Relay 2:
