W Woodman56 New member May 5, 2025 2 Vestal Ny May 5, 2025 Add bookmark #1 I have a 115/230 toggle switch on my pool pump. If I swith it to 230 do I have to make internal changes to the wiring?
T TinFoilHat Well-known member Jul 14, 2023 1,593 Phoenix May 5, 2025 Add bookmark #2 If you're currently running it on 115 then you have to run 220 from a new breaker on new wires to your pump to run it on 220. Last edited: May 5, 2025
Jimrahbe Mod Squad TFP Expert LifeTime Supporter Jul 7, 2014 36,111 Bedford, TX May 5, 2025 Add bookmark #3 56, Show us some pics... of the pump and of the data plates.. It is unusually for there to be a toggle switch to change from 120 to 240 operation.. Are you sure that you don't have a 2-speed pump.. Those often have a toggle switch to select low speed or high speed. Thanks, Jim R.
