I need help, I just bought a new pentair superflow and there is a switch to select 115 or 230 and im not sure which to use. I had a superflow VS and there was no selection on it. I have a normal single pole 20 amp breaker wired to a gfci outlet then wired to the pump all using normal 12/2 wire.
The superflow VS i had was very quit even on the highest setting, my pump is about 20 yards from my pool and i could never hear the pump running.
with the new superflow (Non variable speed) i set it to 115 and it was extremally loud. The water flow was about as good as my old pump but I can hear it quit a bit from my pool. I tried moving the switch to 230 and it did make it quit a bit quiter but the water flow was reduced alot.
I guess i can live with the reduced water flow but is it safe to run it at 230, im not good with electric and didnt know if i needed a double pole breaker.
Thank you in advance for any advice.
