Per Friday's test, the 100 TA will find its own happy spot as you manage the PH by keeping it in the 7s.
200 CH is fine. Modern fiberglass doesn't need any like it did back in the day. Heater recommendations are outdated too, but we suggest following those (200 CH) so they don't void you warranty.
Your CYA will likely need bumping once the summer UV gets outrageous by you, but is fine for now. Add 10 at a time and road test if you see abnormal daily loss at some point.
Keep FC free and clear above min. It's a moving target and if you need to dose over target range to end with enough FC at the end of the day, that's up to you to recognize you're losing 4ppm in July. (Etc etc). Right now it's probably 1 or 2 lost per day so you can run a lower # and still remain free and clear.
Minimum sounds OK but it's a Defcon 1, all hands on deck situation. Call it Swampville instead and you'll give it the respect it deserves when you find you're 1ppm from Swampville.
