FC is 6.5 this morning. Holding a little more chlorine every night
It usually holds better as time goes by as there is less to kill day over day. But occasionally there is a small bump in the road so don’t get discouraged if goes the wrong direction for a test or five. It is still progress when that happens.Holding a little more chlorine every night![]()
Yes. Cloudy / milky sits at the fine line between mostly and all dead algae. Then it gets more hazy like as you slowly filter the dead stuffs out.Is this still part of the normal process
I don't know if I can log my FC without the premium subscription, which I don't have. I have been deleting my full morning tests from the day before in order to add the current days readings. Maybe I'm doing something wrong.You’re mostly only logging your bleach additions & not your fc results in poolmath so I can’t tell how much fc you’re losing, especially overnight.
There are so many factors from lighting to how fast you squirt the mix..... slow it down tomorrow and do a best out of 5. Reuse the mix and just pour back and forth until you are happy you got it right.Also, my CYA had been at 40 for multiple days in a row, then yesterday it was 50 and today it was 30. Is that most likely tester error? Was just surprised at the fluctuation.
When i saw u had logs I assumed you had the subscription. I didn’t know it would record more than 1 log of any kind w/out a subscriptionI don't know if I can log my FC without the premium subscription, which I don't have. I have been deleting my full morning tests from the day before in order to add the current days readings. Maybe I'm doing something wrong.
I'll be sure to read over that article. I'm sure it needs to be backwashed because we were adding all kinds of stuff from the pool store.
That's good to know. I've been doing it to make sure I've got the right FC for the SLAM. Is it the same with TA? Because my numbers have been consistent. Which just adds more layers of confirmation of how much BS the pool store tests are.Also no need to test cya every day - it doesn’t change much unless u add stabilizer/stabilzed chlorine or exchange water
Do u have a shop vac?Part 6. The tube with the black thing on the bottom. I think I'm going to have to scoop all the sand out to get it back in.
Did sand get down in there? I just worry it would clog the laterals. Or Perhaps you may just get some sand in the poolThis is DEFINITELY a once a year cleaning. When I put it back together I discovered I didn't do anything wrong. When you take it apart the stand pipe comes out with the top part (the whole upper part of the diagram in an above post) and you have to pull the stand pipe out to put it back in. Now I know, lol.
