Pool SOS
Athas08
Active member
Jun 23, 2021
40
Austin, tx
You follow the SLAM Process until you pass all 3 end of slam criteria. Test fc & add liquid chlorine every few hours to MAINTAIN Slam fc level for your cya.
Always round up to the next “10” when measuring cya so yours is 40ppm - this means you need to maintain a fc level of 16ppm. FC/CYA Chart
Every hour you fall below slam level algae wins.
Right, I forgot to check the SLAM article.🤦‍♀️ Thanks
Reactions: Mdragger88
Athas08
Active member
Jun 23, 2021
40
Austin, tx
FC went from 12, to 9.5 at around 11pm, down to 1 just now :(. Plus there's also this white, foamy stuff that wasn't there yesterday.
Athas08
Active member
Jun 23, 2021
40
Austin, tx
So my husband asked a question about the adding the chlorine and I wasn't sure. I know my goal for the FC is 16 based on the CYA. But what if it goes over? And is there a reason to add a half gallon or gallon every hour versus just adding 4 gallons this morning?
Athas08
Active member
Jun 23, 2021
40
Austin, tx
Another question that relates to the SLAM process. We have a vacuum and it worked well once. But when I went to use it a couple of days ago, I got no suction. When I put the filter to backwash, it flows well, but as soon as I hook the vacuum up, it slows to a trickle. Any thoughts or experiences with this issue? Thanks
Newdude
8,764
NY
The 40% number was reached for optimal efficiency. Over it and the FC burns off faster than it helps becoming a waste. No biggie if you overshoot a little bit too far risks liner/equipment damage.
Yes. M for maintain. A constant fight for the Algae. Spiking it and having it be far under optimal efficiency draws the process out.
Is the hose ‘primed’ and full of water before you connect it ? A lot of times of there is still air in the hose it won’t make a good deal to divert all the pump suction through the vac.
Athas08
Active member
Jun 23, 2021
40
Austin, tx
Thanks for the explanation. That makes sense.
I'll try again on the vacuum. It will be tricky not being able to get in the pool (it's nasty, lol) but I'll make it work.
Mdragger88
2,432
Hernando, Ms
Intex Krystal Clear
U can also Stick the hose on the return/jet to fill it with water until u don’t get anymore air/bubbles coming out- then carefully (keeping the hose end under water) move it to the pump inlet connection/skimmer etc. some people try to keep their hand over it to prevent air from going in the hose. Also secure the pole end so it doesn’t fall in the pool - it helps to have 3 hands 🤣
Athas08
Active member
Jun 23, 2021
40
Austin, tx
I'll make my 12 year old help me, lol
Athas08
Active member
Jun 23, 2021
40
Austin, tx
Th
This worked and I didn't even have to employ the begrudging help of a 12 year old.
Newdude
8,764
NY
No worries. Stay the course. It’s 1% or less of your FC most times as long as you’re mixing. You won’t be able to even tell.
Reactions: Athas08
AK-
364
Randolph, NJ
Thinking about the future... once you are done with the SLAM:
1 - Never let your FC drop below target. It is safe to swim up to SLAM level. If you plan to not let it drop below target you won't be in trouble if something unexpected happen.
2 - If you don't take the pool down during winter keep it chlorinated at or above target all times (I don't think you are going to close it where you live)
If you follow those two you won't ever have to SLAM again.
Newdude
8,764
NY
+1. And to expand on this, You can aim for target level, consume your daily chlorine and be at or slightly above minimum. There is very little room for error here. If you aim above target, and fall back into range with your daily loss, You have about 4FC for insurance before minimum. Until you know your pool backwards/forwards I always recommend running hot. That safety net may save you going through all this again.
Once you are your own pro, you can dance the fine line as close as you wish. When I saw how good it worked, I never dropped mine and kept it hot. Many others do too.
