- Jun 1, 2018
- 16,056
- Vinyl
- Hayward Aqua Rite (T-15)
Let’s back up-
You tested at 11:15 & had 8ppm fc
then added 32oz of 10%? To get u to 12.5 calculated.
you didn’t test again until 3:30 so you can’t know that you ever really got to 12.5 ppm after the 11:15 dose (maybe, maybe not) so everyone is suggesting u test about 15 minutes after dosing next time to confirm that your bleach is as potent as it’s supposed to be. If its not, use more to compensate. Bleach degrades over time slowly turning to salt water, depending upon how it was stored (in the sun/heat) this can occur more quickly. When purchasing you can check the julian dates to ensure your getting the freshest possible
