Pool SOS
Athas08
Active member
Jun 23, 2021
40
Austin, tx
Are you sure you added the pool water to the diluted test? Or the test solution to the pool water/tap water mix? Something went wrong here, because you can't go from 100 to zero in three days unless you replaced all of your water.
I did it again and this time it was almost to the twenty. About half a finger width below the 20 mark. This is when it was in the shadow of my body. When it was in bright sun, I could still see the dot. I don't know if that matters.
Donldson
4,969
NW Ohio
Do you have liquid chlorine? If so, use PoolMath to determine how much to add to bring your water to 10 ppm FC. Add that, let it circulate for 10 minutes, and test your FC.
This test will determine if the only possible cause of CYA dropping that fast has happened.
crimson avenger
316
Chicago
Fiberglass
Pentair Intellichlor IC-20
If that's what it takes. We've barely used the pool this summer.
I have a 2300 gallon pool.
I struggled with a SLAM for 2.5 weeks earlier this summer (not actually that long ago).
I decided it was easier to drain/refill - and I was right.
Learn your proper testing, and consider a drain/refill.
Athas08
Active member
Jun 23, 2021
40
Austin, tx
I do and I'll do this.
We've dumped so much money in chemicals this summer it's ridiculous. If it's going to take a lot more in chemicals to do a SLAM, then we might as well refill.
Reactions: crimson avenger
Athas08
Active member
Jun 23, 2021
40
Austin, tx
FC is 1
Donldson
4,969
NW Ohio
Well, it sounds like you've experienced an ammonia conversion over the weekend. It's really rare to happen during the season and over the matter of a couple days, but it's about the only way for your CYA to have dropped that fast and losing FC that quickly after adding it is a symptom of it.
I'd say if you're considering a total drain and refill then you don't really want to mess around with more testing and chlorine. If you go with the full drain option you'll want to test and adjust the pH right away after refilling, add 3 ppm of chlorine, and 30 ppm of CYA. That'll get you off to a good start.
Athas08
Active member
Jun 23, 2021
40
Austin, tx
Is it easier to do a full drain than to mess with the chemicals to get it back?
MITBeta
341
North Attleboro, Massachusetts
Halfway to the bottom of the label with tap water, the rest of the way to the bottom of the label with pool water, then to the top of the label with the R-0013.
If your CYA is that low, test again without diluting. Fill to the bottom of the label with just pool water and the rest of the way with R-0013.
Reactions: Mdragger88
Mdragger88
2,432
Hernando, Ms
Intex Krystal Clear
It was at 100 Thursday. But I'll do a regular CYA test in the morning.
This is why i love/prefer the tf100 over the k2006- you get plenty of regeants so you can re test when needed & don’t feel like u will run out when getting the hang of things.
Reactions: Athas08
Newdude
8,762
NY
I'm sure that I followed the directions
You did. But in the wrong order. Let’s break it down again….. :)
fill pool water to the label. Fill the rest of the way with R-0013. Shake and wait.
now mix the ‘mix’ with and equal part of tap water. So you are cutting the mix in half, not cutting the half mix in half.
Athas08
Active member
Jun 23, 2021
40
Austin, tx
Ok, lol. Let me just double check then. Fill the bottle with the red cap as if doing a regular CYA test. Then dump half that out and replace with tap water. Then pour into the CYA view tube as usual.
Newdude
8,762
NY
That’s it. Same steps but different order. Instead of X2 your way was X4 if my napkin maths is correct. It’s good that you read a 20 because when you get the X2 result it should be the 80 or so we hoped for in the first place. If you were seeing 50 the way you did it, you’d have 200ish.
Athas08
Active member
Jun 23, 2021
40
Austin, tx
I got 60, so 120 right?
Newdude
8,762
NY
Yes. Perfect. 120 it is. Draining/lowering CYA is an even %. Half is half and so on. A 58% drain would leave you with a 50 CYA and be much more manageable for FC maintenance. You’ll probably want a 40 in TX anyway so you might as well drain your smaller pool 66% to get there.
Athas08
Active member
Jun 23, 2021
40
Austin, tx
Thank you.
Newdude
8,762
NY
Could my CYA be so high because I've been using the powdered shock to raise chlorine levels?
If it’s stabilized with Cyanuric Acid then that’s where it came from.
Going forward you’ll read all labels and know what you’re adding, what it will do, and you’ll verify it did what it was supposed to do after adding it. :)
*also for future knowledge, the powdered shocks and tabs/pucks are either stabilized with CYA or calcium. You can pick and choose when you need what, or how much room to spare you have at times. Overall you will want only liquid chlorine / bleach / sodium Hyperchlorite more often than not.
Reactions: Athas08
