1 - measure FC with sample from point away from your returns (or with pump off).
2 - measure FC with sample with pump on and captured from water coming from return. Make sure pool pilot is set to 100%. Otherwise, it may not be producing when you take sample.
If the values are the same, you are not producing FC. You should see much higher value with sample 2 (from returns).
If producing FC and you have an issue maintaining level, then take full set of chemical readings FC, TC, PH, TA, CYA, salt level and post.
Note - a salt water chlorine generator (SWG) will not produce when water temps are near and below 60 F.
Also, under the maintenance menu there is a Test Pool Pilot selection which will display information about system, like the water temp and power level being sent to cell. You can examine these. Details in manual.
Finally, check if any warning lights/messages on display.
