Pool levels help
DonnieTheMan
Active member
Apr 3, 2021
35
Houston
So I’m testing the FC and CC this morning and so far I’ve put 60 drops of R-0871 and the sample is still pink. Surely I don’t just keep adding drops do I?
DonnieTheMan
Active member
Apr 3, 2021
35
Houston
I guess I’ll just take a sample to Leslies and go from there. I’m not sure what I’m doing wrong or if my levels are just so high from adding the 3 jugs of chlorine last night.
mknauss
39,695
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Never been in one, what do they do? :mrgreen:
Just follow the above test directions. If by chance your FC is above 10 ppm, then your pH test is not valid.
mknauss
39,695
Laughlin, NV
Fiberglass
Directly from the above directions I posted --
Fill the sample tube with pool water to the 10 ml mark.
Using the small spoon shaped end of the dipper, add one heaping dipper, or two level dippers, of R-0870 and swirl to mix.
cowboycasey
6,884
Southern OK
trust me, they don't know how to test correctly..
once you get this down it really is easy..
Fill to 10ml with pool water
1 scoop or powder of R-0870 (turns pink is all you need)
add R-0871 one drop at a time until it turns clear (it will turn clear)
by using the 10 ml you use less reagent R-0871
Reactions: DonnieTheMan
revitup
457
Pawleys Island, SC
Fiberglass
Hayward Aqua Rite (T-15)
One scoop or two, doesn’t matter. Same result.
DonnieTheMan
Active member
Apr 3, 2021
35
Houston
What I’m concerned about is the number of drops to turn the sample from pink to clear. I’ve put in 60 and it was still pink. I don’t want to waste the product. That’s why I was asking if I’m supposed to test the next day after adding 3 128oz and a quart of liquid chlorine.
DonnieTheMan
Active member
Apr 3, 2021
35
Houston
And this is why I’m confused. Couple ppl say 1 scoop, you say it doesn’t matter. I’m not trying to be a pain, I’m just trying to decipher what it is exactly I should be doing and the right way to do it.
mknauss
39,695
Laughlin, NV
Fiberglass
You have a 6000 gallon pool. That was way too much chlorine. Check your data in Poolmath. It will take a while for that chlorine to dissipate.
DonnieTheMan
Active member
Apr 3, 2021
35
Houston
I asked that question a couple times yesterday and I was told that was the correct amount based on this:
mknauss
39,695
Laughlin, NV
Fiberglass
I could not read that as it was so dark. Share your Poolmath data so we can see it more readily.
Regardless, you must have the incorrect volume for your pool in Poolmath. Check that.
DonnieTheMan
Active member
Apr 3, 2021
35
Houston
Looks like you calculated for 60000 gal, not 6000.
You sir are absolutely correct. I accidentally added one too many 0’s. FML. I meant to put 6400 and I had 64,000. So now what? I just hope that much bleach doesn’t turn all the blue squares in my pool white. 🤦‍♂️🤦‍♂️🤦‍♂️
cowboycasey
6,884
Southern OK
Ohhh wow.... That is exactly what happened, you used 60,000 gallons
It raised your FC to above 50 FC
I can say anything that was growing is dead.... really dead... it will probably bleach out your liner but it may not be to bad... do not swim right now...
DonnieTheMan
Active member
Apr 3, 2021
35
Houston
Yessir, it was the wrong volume. I’m a dumb Rear, 100% 🤬🤬
DonnieTheMan
Active member
Apr 3, 2021
35
Houston
So after 2 days of sun, I tested my FC just now. I used the 10ml mark and added one heaping scoop of powder. It took 17 drops to clear it up. So my FC is 8.5 if I did the math correctly. It’s crazy how the sun eats up the chlorine that fast. I was only supposed to add 41oz of chlorine, not over 3 gallons lol. Lesson learned though. Thanks to all that helped me out.
Reactions: cowboycasey
