reggiehammond
- Oct 4, 2020
- 2,253
- Plaster
- CircuPool RJ-60 Plus
YesI don't recall - but are you on well water?
No problem, thank you.Hold on for more advice.
I wasn't sure if it was pollen/other debris or iron. I noticed the skimmer sock was a rust color as well - is that helping catch anything or just stained from the iron? Outside of rigging a 5gal bucket into a makeshift Polyfil filter (not sure if that is preferred vs stuffing the skimmer basket), anything else I can do to help along the process?Polyfill looks to be grabbing iron.
Thank you. My only concern was my pH is very low (pure yellow color on the test which looks like 7.0 but could be lower). I had some concern that if it is very low that it could be damaging my pool pump and potentially releasing metals in the water from corrosion, so I wanted to bring it up to at least 7.2.High pH precipitates iron. But if you are trapping it currently, I would not change anything.
