- Jul 21, 2013
- 65,634
- Plaster
- Pentair Intellichlor IC-60
You also have to select PUMP ON/OFF.I'd prefer to select a valve (open/close) and have the pump adjust RPM as pre-determined. I assumed this was a capability of the IC system.
You have a set speed for PUMP ON.
Each valve has an A setting and B setting.
The default pump setting applies to A.
If you select the valve button to change to B you can set an increased pump speed.
You can create a macro button that turns pump ON and sets valve to B with one selection.
You can also create a Feature Circuit that is just a pump speed increase.
Those are the basic programming options you work with.
