- Jul 4, 2020
- 501
- Vinyl
- Pentair Intellichlor IC-40
Happy Saturday!
Our new pool gets underway on Monday, and I'll be responsible for plumbing the pad and setting up the equipment (my request, because I'm a perfectionist, and want it set up in an ideal way). Note that I've listed all my equipment in my signature. A few questions:
1.) I am planning to use Pentair 263029 valves everywhere based on the reading I've done here. I will have two skimmers, which I'll run 2" to, but were unfortunately ordered with 1.5" outlets. I plan to just reduce the suction line to 1.5 right at the skimmer. My question is this: Should I do a 3-way valve on those and then go into the suction side of the pump, or am I better off to have individual valves and tie them together after the valves? I'm not sure how those 3-ways are configured, and if they would allow mixing between the skimmers, or if it would only be on/off so that only one skimmer would be selected at a time.
2.) I also plan to have a valve on each return. Are there other places I should consider installing valves?
2.) I plan to run 2" to each return, then reduce to 1.5 at the eyeball. Is this overkill?
3.) Pool equipment will be located inside a 12x16 pool house with a concrete floor. I see cautions on not pouring concrete around the PVC where it goes into the ground when a simple pad is used so as to avoid breaking the pipes if the pad moves from freezing./thawing (an issue for sure here in Ohio). Should I consider forming out a section of the floor to keep in gravel to avoid that, or is that not a concern given that this will be a full pad that the pool house will sit on? It would be easy enough to do.
4.) I plan to install things in the following order: skimmers - pump - filter - anode - heater - salt cell (vertical mount, at least 3' of pipe between heater and cell) - flow meter - returns. Does that sound right? Where in that sequence should check valve(s) be?
Anything else you'd advise me to consider or keep in mind?
Thanks so much - I can't imagine going through this process for the first time without this forum.
Wes
Wes
