- May 3, 2014
- 62,717
- Fiberglass
- Pentair Intellichlor IC-40
A typical swcg will last 5-7 years if sized properly. Mine is 8 years old.
Note that Marty has a 40,000 gallon cell for a 6,000 gallon pool. Over 6X oversized.
Jim,I suggest that you use 2-way valves on each skimmer line and replace their 3-way valves with simple "T" fittings. The only 3-way valve will the Intake valve which is the one in front of the pump. Using 2-way valves on each skimmer line gives you much better control than trying to balance your 3-way valve set up. Much easier to repair or modify later if you ever need to.
I would do the same thing on the Spa Common Return line. Only the Return valve would be a 3-way valve.
Am I on the right track?
Jim,The only thing you might add is a heater by-pass.. Not required, by nice to have.
Jim,
What is the advantage of having a bypass?
Duffy
AJW,Heater Bypass - Further Reading
www.troublefreepool.com
Do you not agree with Jandy's schematic?I'm not a fan of the 3 way valve after the heater there's always a chance of dead heading the pump and the danger of bursting the heater core. A 2 way is safest and worse case senerio the water goes to the wrong place but pressure on the heater can't be good.
