- Dec 14, 2021
- 288
- Plaster
- Pentair Intellichlor IC-60
Greetings and Happy New Year! We've narrowed our PB selection to two finalists. Both are reputable but I am receiving different opinions regarding how to plumb the project, pipe sizing, pumps, etc. For example, one contractor suggests using a single pump and plumbing the returns to the sheer descents separately and using the filter pump for the bubblers and the other suggests using a single water feature pump to supply both the bubblers and sheer descents but the bubblers and sheers would have a single pipe "teeing" into splits (3 for sheers and 2 for the bubblers) each at the pool.
This is such a great site and I've learned quite a bit by exploring. Additionally everyone is very giving of his/her time in helping novices such as myself better understand the process of building and operating a pool and how to avoid the many pitfalls. Thanks in advance for any and all suggestions with regards to how I can make my build as successful as possible!
Here are the planned specifics of the project:
Pool/Spa Specifications:
Shape: Geometric (Infinity Edge)
Pool Dimensions: 32’ x 26’
Depth: 3’6” to 5’6”
Volume: 16,000 gallons
Spa dimensions: 7’ x 7’ (2-Sided Spillway) Pool Level
Infinity Edge: 25’
Catch Basin: 26’Lx3’Wx4’D
Raised Wall: 16’6”Lx12”Wx12”H
Fire Bowls: Wok Style 28”x28” – 3 ea.
Columns: 2’Lx2’Wx18”’H – 3 ea.
In-Pool Table+Bench
In-Pool Seating Bench
Equipment/Water Features:
Filter (Pool): Pentair Clean & Clear Plus 520
Filter (Basin): Pentair Clean & Clear Plus 320
Chlorinator (Pool): Rainbow #320
Chlorinator (Basin): Rainbow #320
Ozone/UV Sterilizer: Clear 03 Ozone + Ultra UV2
Pump (Filter): Pentair IntelliFlo VSF 3HP
Pump (Edge): Pentair IntelliFlo VSF 3HP
Pump (Water Features): Pentair SuperFlo VSF 2.2HP
Cleaner: Pentair 930 IG Prowler or Polaris 9650iQ
Pool Skimmers: Hayward 2” - 2 Ea.
Pool Lights: 5 Pentair Microbrite
Spa Light: 1 Pentair Microbrite
Basin Light: 1 Pentair Amerlite 12V
Main Drain: A&A Dual Channel Drain
Spa Drain: A&A Dual Channel Drain
Basin Drain: A&A Dual Channel Drain
Controller/Interface: Pentair Intellicenter i9+3 w/SmartLogic2.
Air Blower: Air Silencer 2HP
Spa Jets: 8 therapy jets
Heater: Pentair MasterTemp 400k BTU Natural Gas
Illuminated Bubblers: Pentair Colorvision – 2 ea.
Scuppers – Sheer Descent 2’ – 3 ea.
Leveler: Levolor K1100
Transformer (Bubblers): Pentair 300W
Transformer (Pool/Spa lights): Pentair 300W
Transformer (Landscaping lights): Pentair 300W
Structural Specifications :
Steel (Beam): 12” Box Beam #4 rebar on 8” centers
Steel (Wall/Floor): #3 rebar on 8” centers
Gunite (Beam): 12” X 12”
Gunite (Wall/Floor): 6” Minimum
Gunite (Coves): 8”
Gunite Mix: 6 sacks cement/1 yd sand
Steps & Benches Per Plan – tanning ledge with 2 bubblers and 1 umbrella sleeve
Additional Umbrella Sleeves – 4 (Spa, Bench, In-Pool Table, Seating area)
Plumbing Specifications:
Pool Returns: 2.5” – 7 ea.
Edge Return: 2.5”
Spa Returns: 2” – 2 ea.
Valves: Pentair
Overflow Line: 2” Run with Pop-up
Finish Specifications:
Tile: Travertine
Coping Travertine
Interior Finish: Pebble Sheen
Deck Specifications:
Deck Type: Travertine - 500 sq ft
Sub Base: Stabilized sand w/concrete perimeter
Footers: Concrete
Custom Steps (Lighted): 6 ea
Drainage System: 4” PVC with pop-up
Depth: 3’6” to 5’6”
Infinity Edge: 25’
In-Pool Table+Bench
Gunite (Coves): 8”
Edge Return: 2.5”
Valves: Pentair
Tile: Travertine
Coping Travertine
Footers: Concrete
