Hi folks, I've been pulling my hair out trying to run down the problem of why my heater will not ignite the burners. I've cleaned the jets out, checked the gas pressure coming in to the gas valve ( I have 12" WC as indicated on the decal inside the heater compartment that it requires). Cleaned off the flame sensor, checked voltage to the valve and got 27 volts. I can hear the valve click after a bit when the hot surface ignitor glows red, but there is no gas flow out of the valve when this happens ( I hooked up manometer to the output side of the gas valve to check). What am I missing?
