roundrocktxpool
EasyTouch2. I deleted the data files and got it to find it.. Now to get past the lat/long warn
Simply click on the gears icon at the upper right. Then select the general tab. You may enter the latitude and longitude there. This will allow your EasyTouch to schedule sunrise and sunset schedule times.EasyTouch2. I deleted the data files and got it to find it.. Now to get past the lat/long warn
This one: https://www.amazon.com/gp/aw/d/B07SD65BVFThat should be a fine location to connect the USB adapter. Which adapter do you have?
I will do that. Just wanted to make sure I included progress here if it helps other folks trying.Are you sure you have the D+ and D- hooked up correctly. The screenshot is what happens when there are no comms. We will be able to help you better if you click on the link above and submit an issue. The may even be a chance that somebody has used that adapter.
You can use them both.Just bought a screenlogic2 off Ebay and installed it in the easy touch panel with a mini access point to connect to my home internet.
Then I found this.
Kinda want to return the SL2 now lol.
So… my port forwarding isn’t working. I have plenty of other devices that I can access outside my house, but the Pi is putting up a stink. I’ll have to investigate more. I assumed that I would port forward the IP address of the pi, that doesn’t seem to work.Yup... Been down a lot over the last 24 hours.
