My wife and I are just finishing up a country house which we've built ourselves. I've no experience with pools so any pointers, tips and advice are welcome!
We just got started on a 12x20 rectangular fiberglass pool that is sited just off our elevated rear concrete patio. This will be a partial in-ground pool with a new retaining wall on 3 sides, and the existing foundation wall forming the 4th side. (drawings attached). The 4.5' deep pool has a flat bottom. The pool deck will be a 4" step down from the existing concrete patio, which is a suspended slab, about 40" above grade.
The footings for the the retaining wall were poured yesterday. There is vertical rebar set for the retaining wall. A bond beam will be built into the wall. I am considering pavers for the deck instead of poured concrete, for looks and to have access to plumbing in case of leaks.
The pool arrives next week, to be set on a gravel base by our excavation contractor. Once in place I will do the plumbing and electrical. Then I'll have a mason build the wall followed by gravel backfill. I am ordering gravel for the base. I think #89 crushed stone will be a good choice but have found no definitive answer.
