Standard uniform hasn't changed in at least 5 years!
I love using open web truss joists for second floors! Doing it right
I love using open web truss joists for second floors! Doing it right![]()
You guys need your own TV show, the next logical step after your blog. BLOG Hambels Get Real
I just browsed through you home renovation blog. You two are amazing!
Thanks! We just really like projects
Today we coated the bondbeam with super blockade. One more coat and then it's on to thinset then coping!
Mike pressure washed the bond beam before we "painted" on the super blockade.
I'll be doing my coping soon, what was the point of the super blockade and where did you buy it?
I couldn't see anything in the super blockade specs for tile over the material. How does it handle thinset? I like the fact that it stops effervescence but I'm concerned how the thinset and plaster will adhere. Any info on that?
OK.
I'm officially DIY jealous. i Just finished underground electric, and have inspections tomorrow (Friday 5-5) but I feel you all are killing me :|
I do have coping questions: when I pass underground electric and plumbing in about 7 hours, I'm on to decking. I would like to pick your brain on coping.
You used Super Blockade for water proofing, go it. You just filled my Saturday.........
What did you use for the mortar? Typical stone thinset? something special for outside?
You questions the grout in several post, what did you find was the best solution fro grout? (we are using a Travertine coping)
I would imagine it wouldn't be in their spec sheet but in the thinset's on what substrates it can be applied to. Super blockade is a Portland cement based product so thinset won't have any adherence issues.
This is an typical industry use for super blockade![]()
it's a regional product. Merlex is located in Orange County and services the western side of the United States...although their website says they would be willing to send anywhere I imagine that would only be to wholesalers and large quantities.this is interesting. i was on their website. is this available anywhere or is it just a somewhat local california company. i just contacted one of my local concrete supply houses where i bought my concrete sealer when i built my home. they are going to get back to me.
Maybe because it's a regional product? I've seen it in other people's pictures...is this common practice with installs of concrete pools? thesis the first i'm reading about it on someones build and i'm really interested in using it.
Always read the spec sheets you plan to use and make sure they work with the type of tile you are using and the substrate and the application.do you know if it issue for use on gunite also? i realize they are similar but gunite and shotcrete are diff. do you have to watch what type of thinset you use for the tile then?
