- May 3, 2014
- 58,745
- Fiberglass
- Pentair Intellichlor IC-40
Did you do the dilute test for the CYA? If not, use 1:1 pool water and fresh water. Mix that up and use that for the pool water sample and do the CYA Test again. Double the result.
Start planning where you will send at least 8000 gallons of water or so.
