Old Member, New House and Pool
clambert1273
629
Gilbert, AZ
So do you run all three at the same time or just the normal returns with the other two not very often.
My take on the install would be to turn the filter 90° towards the pump that way you should have enough room for the cell possibly even horizontally.
that was where my mind went as it was the only logical way for it to maneuver, it's just a weird setup and my goal is to eventually have that whole area redone
wireform
In The Industry
Aug 15, 2017
1,475
Spring Valley, NY
Going that route I would cut A,B,C and E , spin the filter around , replace bother valves mounting them horizontally and fit the SWCG between the output of the filter and the new valve setup. Screenshot_20200413-192103_Chrome.jpg
wireform
In The Industry
Aug 15, 2017
1,475
Spring Valley, NY
You may as well and call it done OR leave A,B and C alone and just cut E but, I'm not sure of how much there is left (E) and how it connects to the filter. Is there a mechanical connection like a threaded collar. Can't see from the pictures the specifics. Let's hear what others here recommend.
clambert1273
629
Gilbert, AZ
here is theE area
wireform
In The Industry
Aug 15, 2017
1,475
Spring Valley, NY
I guess if you have at least 1+ inches between the green and the red you can do it. You would cut max to the red side leaving the white part in the filter valve and then use that for the new plumbing. Screenshot_20200413-203850_Chrome.jpg
Reactions: clambert1273
proavia
1,955
Chandler AZ
I guess if you have at least 1+ inches between the green and the red you can do it. You would cut max to the red side leaving the white part in the filter valve and then use that for the new plumbing. View attachment 132658
Would it also work if the OP were to cut on either side of the coupling (the red line and at the Jandy Valve)? And then use a larger fitting on the Jandy valve side with a reducer back to the original pipe size?
Turning the filter 90* certainly looks like the best option
wireform
In The Industry
Aug 15, 2017
1,475
Spring Valley, NY
Not familiar enough with what fits over what. You may be right and I thought of that option too but as I'm not sure I don't advise. We'll need to have the crew chime in on this one.
clambert1273
629
Gilbert, AZ
As another update with SWG coming this week and needing to redo my plumbing anyway, I started thinking about a new pump either dual speed or VS.. I figured my hubby would flip out but he surprisingly said go for it so im open to any recommendations here for that
Pv2
741
south east Arizona
beware, he may be planning a new toy for the shop (or whatever his hobby might be) :ROFLMAO:
  • Haha
Reactions: kimkats
