- Jun 13, 2013
- 1,513
- Plaster
- CircuPool Edge-40
The trees over the pool will surely keep you busy.
not if my husband will let me remove it like I want to lol it's already on my nerves
On of my fav colors too!! LOVE IT!
That pool looks SO much better already! Now give that company a call that Matt told you about to get that line off your tile and it will be very close to purrfect!
Kim![]()
Christina, Girl you just can catch a break!
I do have an idea about your filter pressure and poor return flow.....................pump impeller! If you have stuff caught on the impeller that will mess with all of that. How to fix:
-turn OFF the breaker to that pump!
-disconnect the pump from the pump basket (share a pic and we can help you figure it out how to get it apart if you needs up to)
-look right in that hole where the basket came from. Is there anything in there? The times I had this problem there were a few leaves in the impeller.
Lets see what you find and we will go from there!!
Tell your hubby you have TFP for a LOT cheaper than hiring someone!!!
Kim![]()
Let us know what you try and what happens when try each one so we can learn from you!!
And that is the MAIN reason I have a robot cleaner now! I got SO tired of cleaning the impeller. Nothing I did kept stuff from getting to the impeller with the suction cleaner!!!
I would get a bigger SWCG. You live in Arizona. Just 2X sizing is not much. You will be running it 12-14 hours per day at 100% to get your FC needs. With a SS pump, that can get expensive.
As far as plumbing, others are better than I. Explain what the three lines on the return side all go to. And if you run through all of them or just certain ones.
