- Jul 21, 2013
- 65,118
- Plaster
- Pentair Intellichlor IC-60
Do we also need a flow meter?
Anti freeze pump?
No.
The IntelliCenter has freeze protection.
Anti freeze pump?
No to both. The equipment list looks goodDo we also need a flow meter?
Anti freeze pump?
Have you discussed how the will backfill those deep fills with the PB? They should be compacted in lifts so the dirt does not settle under your new deck. Check out this thread with the same type of pool for a discussion on proper backfill.Things are going really well. ??
How many gallons in the pool?
If over 25,000 gallons you should get the IC60.
I don’t know yet ( gallons). Will be 20 x 40.
Length x width x depth x 7.5 = volume (in gallons)
20 x 40 x 8 x 7.5 = 48000
Ok.That is too high. You need to use average depth that is typically about 5’.
Today PB informed that our pool will have 28000 gallons.
Close to what I thought.
You want your SWG capacity to be 2X your pool volume. The IC60 is what you should get.
I would prefer the cartridge over sand but there's nothing wrong with sand filters.
Get the larger cartridge if you go that route- the C&C 520
I don't recognize the model number. IC usually means salt cell.@bdavis466 are C&C 520 the same as IC520?
IC is preface for the swg u want an IC60 not a 40. You want a VS pump not a VSF. As far as their backfill it is very poor judging by the picture. I dont see a compactor anywhere. Hes doing a nice job overall but something as important as backfill for your deck is not worth skimping. With a concrete wall liner pool you can jumping Jack right against the wall and do it nice. I'm hoping you are not planning for pavers or stone decking anytime soon
