How thick is that wall? That is not going anywhere!
MicroBrites or GloBrites?
Is it right that GloBrites uses a proprietary housing that no other lights fit?
Is it right that MicroBrites are not as bright as GloBrites?
I would go with MicroBrites considering it is the newer product, fits a standard 1.5” hosing, and does not have the failure history of the GloBrites.
Just about all pool LED lights seem to be problematic so we will see how the MicroBrites age. @ajw22
Yes.
The MicroBrites are smaller then the GloBrites.
I would still go with the microbrites. There isn't enough difference between the two as far as brightness goes.
Unfortunately 3 lights probably isn't enough to completely light your pool.
Hey guys sorry I need you again.
Pump. VSF or VS ( painter).????
Get the simple Intelliflo 011028 VS pump.
No need for the fancy F feature. It is really no use.
We will have a 20x40, salt, vinyl, 3 globrite lights, 1 slide, 1 water fall and 1 bubbler.
No heater.
Is this ALL we would need:
Automation: Pentair IntelliCenter - with SWCG PowerSupply
Filter: Pentair Cartridge - CCP520
Salt: Pentair IC60
Pump: Pentair IntelliFlo VS - 3HP (SKU# 011028
Please and thank you.
light problem...............you can always put an outdoor light right by the pool! One of those pretty black iron post lights. Get them to run some conduit to where you think you will want the light and thank me when you see how pretty it is!
Kim![]()
GloBrite lights or MicroBrite lights?
You want all Jandy NeverLube valves, no ball valves.
You want indoor control panel on IntelliCenter in case you have a problem with the network connection to it?
