New to TFP but not new to pools - numbers are off
That’s not where TFP likes to keep it. You didn’t hear that here.
@ TFP we follow the
FC/CYA Levels
High target 🎯 is where you want to keep it/dose to so you don’t ever go below minimum 🚫 where nasties will grow.
It is safe to swim with fc anywhere between minimum & SLAM level for your cya - which is max) - (so long as you can see the bottom of the deep end for safety)
View attachment 474892View attachment 474891
Where can I find one of these tables for a Saltwater Generator? Thanks. I see the calculator but would like to see a table showing CYA level/min FC/Target FC/SLAM FC all on one table for CYA levels from 20-100 for a SWG...assuming the table is different. Thanks.CYA.JPG
Here's the new one which was modified to add a range for the SWGs like the LC chart. Due to large units needing short run times, overnight only production to save on peak electric costs making it swing during the day like a LC pool, or low loss days letting the FC climb, chasing the hard 5ppm on the old chart was a fools errand.
Where is this chart buried nowadays? All I can find is the new calculator. Calculator is great - but sometimes the chart works better!
But are these available on the website somewhere?
Those are snapshots pieced together from the new calculator results in FC/CYA Levels. There is also a work in progress going on Here.
Everyone's patience is appreciated while things get tweaked. :)
Ok so SLAM levels are the same for LC and SWG? Oops saw the answer above but can't delete comment. Is there a way to do that?
Reactions: newdude
