She's a keeper
She certainly is! She's been a trooper helping me with this and keeping my spirits up. It's been a pretty frustrating job so far. ?
She's a keeper
Put your armor on. lol Look out algae.We are ready for war.
I'm going to run the pump after eating dinner and cleaning a filter and then I will test before 9pm tonight again.
Does this mean you're not running the pump, and you're turning it off? Remember, you need to run the pump as long as possible to clear out the dead algae. Cartridge filters make that more work, but it helps.
Oh I forgot about the electrician.Electrician came today to install some new wiring and outlets on the 2nd floor to get rid of the old knob and tube (my retired dad came over to the house to be there while they did their work). Stupid me forgot that pumps run on electric so the water stopped circulating around 9am until they're all done. Hopefully we didn't lose too much ground.
OH you poor thing! I would not have been able to watch him do that with yelling at him!!!NOOOOOOOOOO!!
Now make sure you both wear "old" clothes" when adding the bleach or put something fairly think over your good clothes to be on the safe side!
Kim![]()
How about some pictures of the pool. This battle needs to be documented!!!
When you buy bleach, buy plenty of DE, because you will be using a lot of it. The downside of how well DE filters is how fast DE loads up and needs backwashing.
Monthly or if the pressure rises by 25% over your starting pressureQuestion: My pool is in good shape now thanks to the advice I received on this forum (I successfully did a SLAM etc etc). But how often should I backwash my filter and add new DE? Once a month? Every six months?
Morning everyone! I talked with a co-worker and I was given a good tip, I'm taking my water to a pool place in town during lunch and I'm having it tested. I'll ask to get a printout or reading of the levels so I can post them here. They'll also tell me exactly what I need.
I'll get the test kit at some point but from what I've seen it's $70-100 - right now if I can get it read for free anytime I'll do that. Once it's stabilized and clear I can invest in that kit.
That's what the pressure gauge is for. After a good teardown cleaning and recharge, you know your clean pressure. Then when that increases 25%, you backwash. So if clean it's 12 psi, you backwash at 15.Question: My pool is in good shape now thanks to the advice I received on this forum (I successfully did a SLAM etc etc). But how often should I backwash my filter and add new DE? Once a month? Every six months?
