"Ok Bob, all you have to do is turn off your filter, throw this in and it will clear right up"I'm just wondering if at some point a chair cushion made it into the pool...in our foreclosure, once the water cleared, we found a cell phone battery, a leaf rake, and a (closed) bottle of floc...which kinda told a tale![]()
Well, ours wasn't a foreclosure. The owners who sold it in 2012 took great care of the property. It had a nice trampoline style safety cover on it which we took off when opening.Serenity, does it pull apart like batting? Is it hard to the touch, or soft? I'm sure its nothing YOU did, but foreclosures are subject to all kinds of shenanigans, from frustrated homeowners to quick fix foreclosure maintenance companies to even the city if it was at some point left open and breeding mosquitos.
So goodness knows what it might be. I guess the best course is to keep on til the water is crystal clear so you can access the integrity of the liner and determine whether removal is viable. The alternate would be to determine now that you want to change the liner. Tough choices, but if you're getting close to clear, I guess I'd keep going and see. It might eventually release.
Haha"Ok Bob, all you have to do is turn off your filter, throw this in and it will clear right up"
"Throw the whole thing in?"
"Yep, the whole thing."
Also, overnight our FC hardly drops...if at all, but come daylight, it drops quicker.It feels like pool math doesn't work for me. I even reduced my pool volume and I add just a quarter of the 128 oz of liquid chlorine, 10% and sometimes it shoots me up 4 FC and sometimes 6, 7 or 8. Using the pool math, my numbers are always off. Now I am just pouring it and testing an hour or so later.
I am not understanding why the calculations are off so much.
Sent from my SM-G800R4 using Tapatalk
Our pump does not seem to have speeds. My pool has two jets, a main drain and one skimmer. I use the jet on the deep end since the other is on the stairs and I could end up damaging the liner using that one.You might need to turn up the pump for better circulation.
Could also be testing error, are you holding the bottle vertically over the tube and slowly adding drops? Do all the drops look the same size? Swirling constantly?
