- Aug 19, 2021
- 1,431
- Plaster
- Pentair Intellichlor IC-40
Electrical is continuing today and based on my reading it appears he is hooking the intelliflo pumps up wrong. As I understand, they should have constant power (ie each pump hooked straight to the breaker) and are then fully controlled by the data line. He has them each running thru the load side of 2 of the intellicenter relays. I beleive I understand that the circ pump goes breaker to the line side of the 1st relay , then staying on the line side of the relay to the pump so that the intellichlor can go on the load side of the relay. The feature pump should just go straight from breaker to pump and not utilize a relay at all from my recollection
@MyAZPool does my intellicenter understanding sound correct?
