New pool with spillover spa - equipment selection
Kram21
12
Perth
Hi
Were about to get our first pool now our kids are confident in the water.
Weve seen a 6m x 4m below ground pool at a local supplier with an aboveground spa which spills over into the pool. Ive been reading up from this website, Dryden Aqua, and a few other sites to produce a scope of what I think we want and which I can provide to a few of the pool suppliers for a quote. By doing it this way Ill understand the system and the functionality.
Id be really interested in any feedback on equipment setups, piping, setouts, lessons learnt etc which others have done and are happy to share. PS were in Perth Australia.
-Were currently not planning on having a separate gas heater for spa, but then it eliminates spa use during winter so rethinking the idea.
-If we go fibreglass pool, pool suppliers here typically only use surface skimmers and not floor main drains due to access incase of leaks. I guess a main drain could be added in the lower side section of the pool wall or isnt this an issue?
-Are we best going a pump for the pool and laminars and another for the spa? If we end up having a swimjet that on its own system anyway.
-Does the spa require a skimmer given its spillover type?
Proposed Specification
Pool DetailsSpa Details
6m x 4m below ground Pool2.2m x 1.8m spillway spa.
1.3m to 1.8m deep1m deep.
Approximate 37,500 ,litre volumeContinuous bench seating for up to 6 people.
Bench seat along one 6m sideApproximate 2.350 litre volume.
6no. 9mm return eyeball nozzles connected to pump return manifold8no. spa Jet nozzles with air connection connected to pump return manifold with efficient 36m3/hr flowrate.
-4no. return nozzles positioned along 6m length, 1/3 from bottom1no. 9mm return eyeball nozzles connected to pump return manifold with efficient 3m3/hr flowrate.
-2no. return nozzles positioned along 4m length, 1/3 from water line4no. 4” spa drains with balance pipe connected to pump suction manifold with efficient 36m3/hr flowrate.
1no. skimmer box with float valve connected to pump suction manifold manifold with efficient 18m3/hr combined flowrate.2no. 4” spa drains with balance pipe connected to pump suction manifold with efficient 3m3/hr flowrate.
2no. 8” main drain with balance pipe connected to skimmer box
2no. 8” main drain with balance pipe connected to pump suction manifold with efficient 18m3/hr combined flowrate.
Class 12 Piping (PN12) –
Return Main DN50 (mhead losses)
Return secondary DN50
Suction Main DN80
Suction Minor DN40
Return Main DN80/DN65/DN50/8nozzles (~4mhead losses)
Suction Main DN80
Suction Minor DN40
Water Feature Details
4no. Laminars into pool. Max total flowrate 9m3/hr,DN32 supply pipe each
2no. spa spillways into pool. Total flowrate 11m3/hr.
Swimjet SystemDN125 main pipe/DN100 at manifolds
Proposed Equipment
ItemDescriptionPt/nSize
1Pump Pentair Intelliflo XF Variable Flow0220053.2Kw0-52m3/hr @5-29mhead.
DN80 connections
2Sand Filter Triton LR100140210V762mm filter diameter/0.456m2Max Flowrate 22m3/hr (48mh)
2” Unions
3Glass Filter Media - Dryden AFM ng (25/25/50)AFM Bulk density 1250kg/m3~250kg
4Pentair Smart UVE80S80WRecommended flowrate 10.2m3/hr
Max flowrate 20.5m3/hr
2” Unions
5UltraTemp VX Heat Pump Top FanUTHP-17-VX17kWRecommended flowrate 7.3m3/hr
1.5”unions
6Intellichlor IC3052055530g/hrMax recommended 18m3/hr
7Spa Blower NO Air Switch10441001.2kW
8Intellicentre i10PS
9Screenlogic2 for iPhone, iPad, Android, PC, MAC520500-AU
10Temperature and air sensors520272
11Intellibrite Multi Plus LED Light + F/Glass Niche + 20m Cable + LV50 Transformer (2 Pack)8050059W Each
12Laminars580001G1.5m3/hr @ 2mhead (1.65m height)
13Intellivalve actuator521485Operates up to DN80 valves
14Intellilevel – Auto level532265-AU
15High performance pool blanket and below ground pool blanket box, Manual operation
16Badu Swimjet System –
Not 100% sold on the swimjet system
Stream Pack Remote2x Speck 21/80-32SG, Single Phase 4.0 HP 1100 LPM pumpMax. 132m3/hr/0.7mhead loss
Flowrates of proposed modes
FlowratesPool Spa Total
SuctionReturnSuctionReturnSuctionReturn
Pool mode – Day (07.00-19.00) - 4-hour turnover - Maintain 28degC water temp.9m3/r9m/hr1m3/hr1m3/hr10m3/hr10m3/hr
(22mh through filter)
Pool mode – Night (19.00-07.00) – 9-hour turnover - No heating. Pool blanket installed.3.5m3/hr3.5m3/hr1m3/hr1m3/hr4.5m3/hr4.5m3/hr
(10mh through filter)
Spa mode -
Increase water temp to 38deg C spa only with selected. Is a Timer function need i.e. 10mins?
3.5m3/hr3.5m3/hr36m3/hr36m3/hr39.5m3/hr39.5m3/hr
Spillway mode - Maintain 28degC water temp20m3/r9m/hr0m3/hr11m3/hr20m3/hr20m3/hr
Spa & Spilway mode - Increase water temp to 38deg C spa only.14.5m3/hr3.5m3/hr36m3/hr47m3/hr50.5m3/hr50.5m3/hr
Laminers (4off) mode6m3/hr6m3/hr6m3/hr6m3/hr
Swimjet mode132m3/hr132m3/hr132m3/hr132m3/hr
Backwash (3min period) mode22m3/hr22m3/hr - 1,100L (48mh through filter)
Pipe Flow Rate Limits
Pipe Diameter u-PVC Class12IDMinimum flowrate (m3/hr) at 0.9m/sMaximum flowrate (m3/hr) at 2.1m/s
DN2529.82.265.27
DN3237.53.588.35
DN4042.84.6610.88
DN5053.77.3417.22
DN6567.011.4226.65
DN8079.015.8837.06
DN100101.726.2761.29
DN125128.441.9597.89
Thanks
Welcome to TFP.
  • A spa does not get skimmers. Surface debris flows over the spillover into the pool to be skimmed.
  • Main drains are not needed in any pool.
  • Get at least 2 skimmers in your pool.
  • Outdoor pools do not require a UV system. You get plenty of natural UV In Perth.
  • Consider a cartridge filter instead of a sand filter with glass media
  • You do not need Screenlogic with the IntelliCenter. The Intellicenter has network communications built in standard.
  • Intellibrite lights are failure prone and expensive. Consider getting Microbrite lights.
  • Consider getting the Intellichlor system IC40 instead of the iChlor. The Intellichlor cells seem to be more relaible and higher quality.
  • You can get the IntelliCenter bundled with the IC40 cell and the Power Center is integrated into the IntelliCenter box.
Things to read....
@ajw22 Thanks for feedback and points taken on board. Regarding the recommended change from the sand filter w glass media to a cartridge filter, what’s your reasoning? Is it reliability?
A couple of years ago cart filters were all the range over sand filters over here but the few PB we’ve spoken to this year are spruiking sand filters w glass media.
Dryden Aqua claim their latest media can filter to 1 micron compared to 8 microns for the best cart filters.
Cheers
