We have had our pool for almost a year now and I am starting to take over the maintenance.
It is running pretty clean. Here is a list of our equipment:
Jandy 1.85HP VS main pump
Jandy 1 HP pump for waterfalls
Polaris booster pump for vacuum
Cartridge filter (not sure which brand)
Gas heater (not sure which brand)
UV sanitizer (not sure which brand)
Aqualink controller with iAqualink access module
WaterGuru Sense
Here are the changes I think I want to make:
WaterGuru Sense
- We have bubblers that are controlled by a valve with the main returns. I'd like to add a VS pump to control them independently. The pool contractor changed the plumbing when the waterfalls were not getting enough flow by adding the single speed pump listed above and pulling the water from the main drain (bypassing the filter). Can I simply pull from the main drain for this pump as well? The main drain is a 4 drain setup that is all connected in "parallel" for anti-entrapment.
- I'd like to install a in-line chlorinator. My though is that putting it in the plumbing for the waterfalls makes the most sense since then I could turn it on and off at will and it would be on when the pool is actually being used. I read that I should be running the waterfalls daily anyway. The pool company says I only need to run about 1ppm of chlorine because I have the UV sanitizer. As stated earlier, the input for this pump does NOT go through the filter though. Would this cause problems with the in-line chlorinator? I think my filter has additional inputs and outputs available. Can I just add another pump to my filter?
- I'd like to pull all the inputs for the pumps off a "manifold" of sorts like it was originally plumbed (before the contractor added the waterfall pump). Is there a reason that that is not acceptable? Each drain and skimmer has a Jandy valve associated with it so I could make adjustments if needed. I could add check valves to ensure water does not back wash into the other pumps.
