New pool owner...trouble with chemistry.
Mojo Risin
Active member
Jun 8, 2019
33
PA
New to owning a pool. Struggling with the chemistry. Should I just ditch the frog system? If so, how do I chlorinate my pool?
ajw22
11,266
Northern NJ
Welcome to TFP.
Liquid chlorine/plain bleach or a salt water generator. Remove the Frog system.
I suggest you read ABC's of Pool Water Chemistry - Trouble Free Pool and
and
Recommended Pool Chemicals - Trouble Free Pool And
ajw22
11,266
Northern NJ
SWG is much less work and you can leave your pool and the SWG takes care of the chlorine needs.
Liquid chlorine you need to check FC and add chlorine every day or two.
Reactions: Mojo Risin
Msch99
387
Verona, MO
We have swg and like it. Fairly easy once dialed in. (Output vs consumption) Generally cost is about the same, you are paying upfront for salt and swg is all.
Read up on swg though, most (me) buy one too small not knowing what we needed. So we supplement with chlorine every day or so depending on sun and bather load.
