- Jun 24, 2016
- 597
- Vinyl
- Hayward Aqua Rite (T-15)
That's not a bad idea!!!! Although I could see Piper (Merle Dane) trying to sit on it.
My 2 hounds need to 'claim' everything. They have 2 choices and both choices involve the letters S, I, and T.Although I could see Piper (Merle Dane) trying to sit on it.![]()
That’s what I was doing but didn’t finish since it started leaking.Weird. Keep us posted with what the PB finds.
Have you deep cleaned from all the construction dirt that it sucked up ?
I sure did and when the pump came on all 4 jets were blowing out dirt. Made me so mad!!Did you backwash and rinse before you went back to filter?
I made up my mind early that with all the dirt blowing, this year wasn't going to count.I sure did and when the pump came on all 4 jets were blowing out dirt. Made me so mad!!
The thing that makes me the most mad is the leaking from the multiport valve handle. Not sure what the Crud that is about but it’s leaking pretty good.Here I was hoping that would be the fix but KNEW deep in my heart you had done it right![]()
I’m about to that point. Ph is still high and I’m about ready to throw in the towel on it. I’ve got another hall one of muriatic acid about to unleash on the pool. LolI made up my mind early that with all the dirt blowing, this year wasn't going to count.
Even with 24/7 filtering, I got hazy at times and it sure as snot wasn't algae with my hot FC in the teens at times. Letting that go mentally, really helped everytime more dirt got dumped/blown in.
With 2 years off, I was rusty and did something similar the first time I cleaned the filter. A few handfuls of dirt got redistributed. But this year didn't count so I blissfully let it go.
Quality control went to crud for *everything*. I'm now almost surprised when something new doesn't have an issue.The thing that makes me the most mad is the leaking from the multiport valve handle. Not sure what the Crud that is about but it’s leaking pretty good.
To be clear, I let the amount of inblowong dirt 'go', the chemistry certainly mattered. But I get the sentimentI’m about to that point. Ph is still high and I’m about ready to throw in the towel on it.
I knew what you meant and I have no plans on letting the chemistry go, just ticked off at the Ph.To be clear, I let the amount of inblowong dirt 'go', the chemistry certainly mattered. But I get the sentiment
It also brings up a great point. What are the plans for closing ? Will you be closing ?
Then vent away old friend.I knew what you meant and I have no plans on letting the chemistry go, just ticked off at the Ph.
I feel that as well. There are many years that winter is a non event, but it does get nasty for some of them. It can be 70, or -3, and how you done go and plan around THAT ???????I had thought about just keeping it open but if we get a bad winter storm and lose power, I'd be in trouble. Usually if power goes out it's for less than an hour but we have had ice storms and lost power for days to weeks.
It just blows my mind that after 2 gallons of muriatic acid that I can't keep the Ph in line. It comes down for one night and boom right back to 8 something. It's not like I have a waterfall dumping into my pool churning up the water. I really don't get it...Ph straight out of the hose is 7.5.Then vent away old friend.
It's joined at the hip with its BFF TA. Eventually you'll pull the PH so many times that the TA comes along too and they both stabilize.Is there anything else that can cause the Ph to continuously be high?
Beat TA into submission without causing to much aeration..LOLIt's joined at the hip with its BFF TA. Eventually you'll pull the PH so many times that the TA comes along too and they both stabilize.
So your log page comes up, but blank so I can't see what's going on. (Not your fault, standard tech glitch kinda thing)Beat TA into submission without causing to much aeration
I'm still having issues with it on my pc.So your log page comes up, but blank so I can't see what's going on. (Not your fault, standard tech glitch kinda thing)
What range are you trying for the PH ? Are you adjusting it a little (to 7.8) or alot (low 7s like you're still working on TA)
