Foxy
0
not 5 heads 12! Lol. It all was ready to be picked at once from the garden or it would bolt. Which means seed and then it doesn't taste good.
Ok on everything
except:
how long between chlorine and acid?
sock! Say what! I think I missed something when reading. I got to go read now. I thought I toss it in?
edit: I just read. In the skimmer in a sock. Like a white gym sock? Pour it in and tie it and throw it in one of the skimmers? Says it might not dissolve for a day or so and to not backwash. Also level of it might not register for a week? So I just let it dissolve and don't worry about that level testing? I bought Clorox brand.
kim you said in front of return? Not skimmer? So tie off a sock hang it on string in front of return using a rock so it doesn't slide into pool?
My pool was plastered a week ago and I did my own startup, so I'll answer about the CYA for you... Yes, you can put it in a white gym sock, tie it and drop it in a skimmer or hang it in front of a return. Then every time you go out to brush, just squeeze the CYA sock (like a stress ball lol) a bit and that will help make the CYA dissolve faster. You can even split the dose in half and use 2 socks in separate skimmers or hang one and skim another, doesn't matter. My pool is a little smaller and it did take about 2 days for the full dose to dissolve. My CYA level registered when I tested it 2 days later and is the same 3 days later, I'll test it again after the weekend just to make sure it's correct.
Your target CYA is likely 30 as a minimum, you can adjust up from there if needed, best to target a little low as it's easier to add than to remove it.
20-30 minutes between chlorine and acid is good.
