Is there anyone around that could add some between that time?Backwashed, rinsed, brushed, skimmed, and added about 1/2 gallon of I’m guessing is ~6-8% of LC for the day since I won’t be able to get to it until 4:30 after work.
It's great, you are making amazing process! Shows your diligence! Definitely keep it up!
The first time you really see the water sparkle, you won't "believe" it!?
You can take a sample to the pool store for metal testing. Metal is either present or not.I was going to add some stain away to my pool, especially since I’ve got high iron and calcium in my fill up water (well). I did run it through the whole house filter I purchased just for my pool during full up (see previous pages with pictures).
Should I wait until after the SLAM is over to add this or do it during?
Darn, I didn’t do the math correct. I read the bottle as bigger and it would raise it 35ppm per 24oz (disregarding the gallons calc). Whoops. I guess then I can add the whole container no problem. I was going to shoot for 20 I think to start.That is fine for CYA - the chemical ingredient it shows is the chemical acronym of CYA.
How much CYA are you planning to add? That bottle holds less than 2 lbs, right? All of it will increase your CYA by about 15 ppm.
